Submasters [Tab 15]
You can access the submaster list by pressing [Sub] [Sub], [Tab] [1][5] or through the browser (Record Target Lists>Submaster List>[Select]). Either of these commands will open a new tab for the submaster list or if it is already open on a tab, will bring focus to the list.
The list view includes a list of all submasters including their labels and all properties. You can navigate within the list by using the [Next] and [Last] buttons or by selecting the desired submaster from the command line.
Editing Submasters
While in the Submaster list, if you want to edit the contents of the submaster, you can select the submaster and press {Edit}. This changes focus to the Live/ Blind tab and places you into the Blind edit mode for the specified submaster. You may also press [Blind] and select the required submaster from the command line.
Any changes made in this screen are automatically stored. A [Record] or [Update] command is not required.
